- 6 Jul 2010
A bit of a strange question, I know.
What is best practice for the spike mounts in cycling shoes (Mountain Bike style)?
At the moment the screw heads are scuffing on the ground and probably over time the screw driver slot will be worn away. So I won't be able to remove them if needed.
Is it best to just remove the screw, either let the hole fill with dirt or put a grub screw in the hole, to save damage to the threaded hole?
^ Internet photo.
I appreciate you've never thought of this before
Thank you.
^ Internet photo.
Thank you.
