£D Prophet 4000XT PCI
12 Jun 2005
Hi there,
Whilst i am waiting for my other gfx card to arrive I am using this one. Whenever I try and do stufff that requrires Directx is doesn't work. Is it that it is not directx compatible or that I need to reinstall directx or something....
Thanks...
Hi there,
OK I have done that, I run the DirectX Features tests I could see:
DirectDraw test results: All tests were successful.
Direct3D 7 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x80004005 (Generic failure)
Direct3D 8 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x8876086c (error code)
Direct3D 9 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x8876086c (error code)
Got those errors, what do i do? Is this why it isnt working?
Thanks...
yOU NEED to install the latest drivers.
Am I right in thinking that is a Kyro based card of some description? Might be hard to source dx8/9 drivers for it, but there should at least be dx7 compatible ones.
Well I have downloaded the latest drivers from the Herculeas website?
Do I need to reinstall DirectX? I am currently on 9.0c i think?
