D300 slow continuous
22 Sep 2009
Leicester
I have a D300 and a Sandisk Ultra 30mb/s and the card is definitely genuine, however I'm getting only about 2-3fps from it. Remove the card and the camera can rack off 8 shots in demo mode. Surely the card shouldn't be limiting, especially seeing as the photos should be held in the buffer before they're written to the card? Is there something I'm missing here?
Dump your settings to a compactflash card and then reset the camera to defaults to see if that helps? If it does it's something setting related, if it doesn't it's probably the card. Genuine or not, dodgy cards aren't unheard of. Easy enough to test with another card...
Set to 14bit I get incredibly slow speeds, back to 12bit and it's at ~8fps
Does it make much difference to be shooting in 12bit? Most monitors are only 6bit and the majority of IPS monitors are still 8bit... I guess I'll keep the camera set to 14bit for normal and 12bit for when speed is a must.
Also check if long exposure noise reduction is turned on as that increases the shooting time as it takes a black exposure after every shot with the same settings in order to reduce noise.
There is actually little benefit of shooting 14bit over 12bit, and that benefit isn't even visible.
I always turn off noise reduction settings.
I did a bit of reading not long after I made that post (I figured I should do some hard work rather than relying on you guys ;)) and it seems the only advantage is when horribly underexposing images, which realistically I shouldn't ever do! I might switch back to 14bit when taking something like a sunset just to 'future-proof' it, but otherwise 12bit is what I'll be using.
14bit does make a very very small difference, so for low speed shooting like landscape work then best to keep it at 14 but uncompressed. For sports shooting, then use 12 bit.
