- 27 Nov 2006
- Coventry
My Alphacool vario D5 pump is over 11 years old. I decided to replace it with a new one, as I was taking it all apart anyway for upgrades / maintenance.
I can't get to the speed adjustment of the vario pump in my current setup, so I got an Alphacool PWM version instead this time (https://www.overclockers.co.uk/alphacool-vpp655-d5-pwm-water-cooling-pump-wc-094-ac.html).
Straight away I noticed the new pump hums a LOT more than the old one. I think there may be something wrong with it. I wanted some opinions before raising a ticket with support.
I run my old vario pump at setting 2-3. Which was 3000rpm and in my system resulted in ~1.3LPH flow.
I've adjusted the speed to 60% on the new PWM pump, to match the 3000rpm. And that's giving me ~1.4LPH at the moment.
Previously I could not hear the pump unless I got right up close to the case, it was "silent". But the new one I can easily hear from across the room. It sends vibrations through my whole desk.
I thought it could be air bubbles, but it's been running for a few hours and the sound hasn't changed. Besides, its too much of a consistent hum to sound like bubbles.
I have not changed the layout of the case at all. It's just been a direct pump swap.
I hope this isn't going to be a big pain in the bottom.
