Have some time to finally build my rig with new components (since the in-laws were about so had no space), and am designing how the watercooling should fit.
I am noticing a lot of vibrations happening when mounting my Alphacool FLT and D5 (watercool) to the side of the Evo XL case (behind mobo tray), and wondering what i can use to dampen the sound. It is very noticeable when i increase the speed of the D5 from setting 2.5 and upwards - think high pitched vibration, and when i set it to the lowest speed, it's like a very deep hum.
Originally i thought it was a pump issue, so ordered another D5 (Alphacool 655) and the same hum occurs.. so it's either pot luck of getting a quiet D5 or vibrations elsewhere.
Would a shoggy sandwich work between the case and reservoir, as i have only seen these with it rested directly against a pump? I've tried those rubber grommets, and they don't help much and i don't have the clearance using decouplers.
At this point, for reference, whilst the DDC is known to be noisier than the D5, i feel the DDC was a lot quieter than the D5 i'm running
