D5100 transfer to iPad
Just ordered that now cheers. I didn't even think to look on apple store, in this kit do you get a USB version and a sd card reader version?
What about something like this:- http://store.micgadget.com/ipad3-card-readers/315-cf-sd-high-speed-card-reader-for-ipad-3.html
I have the older CF only version and that works well.
That looks cool I looked at that after a bought the apple one, I would have bought that if I saw it but cheers anyway
I was merely highlighting the fact that you had ordered something without fully understanding what you'll get.
Something I thought that you'd want to do before paying £25 for something, unless money is of no object.
Hardly being a "smart arse" but whatever :D
Camera Connection Kit works great.
Only downside is that it's a little slow. From what I've read, they nerfed the transfer speed because they discovered that people could use the USB connection to do all kinds of things that they didn't want.
I find it pretty quick,using fast card,not sure if that helps or not with the pad
I'm using quick Sandisk cards with RAW files, it still takes a good 10-15mins to do a full card.
Like I said, Apple nerfed the speed of the USB connection because it allowed people to do all sorts, like use third party keyboards and stuff.
