- 3 Sep 2003
Managed to get hold of a cheap Kood IR filter from the bay, so I've had a little play with it on my K100D with 18-55mm kit lens:
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
![Harbour_IR.jpg](http://img.photobucket.com/albums/v298/BrianInnes/IR/Harbour_IR.jpg)
You haven't heard of IR photography? Really?Fstop11 said:Whats infrared?
Fstop11 said:Sorry Greengiant & Scuzi. Yes of course I have.
At the moment I am taking apart a 350D replacing the sensor hot filter with a custom IR one as we speak.
My comment was pure Johnny Sarcasm because I am excited
Your image is nice. Can I ask what shutter, ISO etc details were used as I am not familiar with the camera you used?
Fstop11 said:So the Pentax takes bloody good IR shots if those are the settings.
I compliment you and encourage you to do more!
Yes Im very brave or very stupid. I guess in a few hours I will know the answer to that!
Just taking the sensor out now!! :O
I think when that happens you're supposed to take a photo of something which would appear "white" in IR (a big patch of grass for example) then set your white balance off that and possibly swap the red and blue channels in post-processing.GeX said:
You seem to be quite in the know about this. Does the Canon 20Da have the same internals as the normal 20D, only with the low pass filter removed?Fstop11 said:They have whats called a low pass filter inside them that blocks out radiation otherwise known as Infrared.
See my thread on sensor cleaning for a visual example.
MikeHunt79 said:Ok, photography noob here... Does an IR filter let thru only the IR, or block the IR?
I've been able to "see" infrared from my TV remote before on my cameraphone, as it has a cheap lens with no IR filter... but I thought all good cameras already have IR filter on the lens?![]()
Anyway, cool looking shot.![]()
sean said:Can I ask, did you do any post-processing to the image and did you apply a custom white balance? I ask because the IR filter I ordered should be arriving tomorrow and I've only ever shot IR on modded webcams and cheapo digicams![]()
Well the 20Da has a slightly different low pass filter engineered to allow more IR light through which will be enough for astrophotography. It will still let it both normal light and radiation (IR)Scuzi said:You seem to be quite in the know about this. Does the Canon 20Da have the same internals as the normal 20D, only with the low pass filter removed?
Or is there more to it than that?
