- 8 Feb 2004
- Dartford, Kent
Fstop11 said:Hoya R72 is the one you need.
awesome
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Fstop11 said:Also had a quick play with yours.
I hope no one is offended by my taking on some further processing its just I work a lot with Infrared and personally feel I know how to bring out the best in an image. This is a very beautiful Image greengiant.
Tonks said:I basically used the workflow as described by Panzerbjorn:
'Auto levels, contrast and colour
Channel mixer: select Red from the drop down and change the Red to 0 and the Blue to 100 then select Blue from the drop down and change Red to 100 and Blue to 0
Hue/Saturation: Select Master from the drop down and change the Hue to 40
Curves: Play around with this but I settled for Input 185 Output 200
Auto levels, contrast and colour again.
Noise reduction and USM and you're done'
I also used this B&W action. Then some burning and dodging to darken the sky and the darker parts of the church and lighten the foliage. Tweaked with curves and finally some unsharp mask- a bit too much perhaps... there is a lot of potential in your shot and someone with more time and skill than me could make it int a stunning shot
Solnyshko said:This of course is what you want:
http://www.dpreview.com/news/0707/07071304fujifilmispro.asp
Last week Fujifilm revealed their third non-visible light (UV and
IR) sensitive camera, the 'IS Pro', this specialized digital SLR is
based on the S5 Pro (which is subsequently based on a Nikon D200
chassis) and is designed to be used specifically in law enforcement
as well as scientific and medical communities.
