Hi Guys,
A little help of you dont mind.
My Rig is as the following.
Asus p5q Deluxe M/B
Q6700
4Gb DDR2 800MHz (Just standard Kingston)
Artic Freezer 7
7 x 80mm case fans, 2 Drawing in from the front, 2 pushing from the back, 1 drawing from the side and 2 on push/pull on the top.
I used to be able to get 3.6GHz out of this on my older asus p5w DH deluxe but since i have cahnged to the new MB that is ment to better for OC'ing i can only get 3.33GHz to get that i need the following.
FSB: 333
CPU V: 1.34
NB V: 1.50 (Not really tried dropping it yet)
DRAM 5.5.5.15 2.2v
on full load I am hitting 90c that is way to hot. the only thing that is different is the direction the cooler is facing. it was facing out the back but now it is facing up because of the NB heatsinks.
Also i noticed that the new board has the 8pin CPU power plug, my PSU only has 4pins. Do i really need the 8pin?
What setting should i be looking at to get the best out of the q6700, why have i got such high temps, and what memory should i be looking to get as a replacment?
thanks guys, I just want my 3.6Ghz back.
Asus p5q Deluxe M/B
Q6700
Artic Freezer 7
FSB: 333
CPU V: 1.34
DRAM 5.5.5.15 2.2v
