ah ok, that's correct then
you can, if you want to. no difference really...Why cant I keep the sound card in the pciex 1_1 slot?
100mm+ sli bridge should fit: https://www.amazon.co.uk/flexible-P...coding=UTF8&psc=1&refRID=E1SMQ5EMRZCQDK24031R
oh whoops.That’s 92mm, will it still reach? I will order now for tomorrow.
ummm... @2K4KGamer you're gonna hate me lol. actually either of those will fit. i miscalculated and added an extra PCIE width. you only need 82mm+
so...yeah...either will fit.
it's bf and it's nothing to worry about."6f" or "bf". Not sure what that means but is it nothing to worry about?
if you don't know what you're doing, just leave it. but it's extra performance there to be tapped when you feel like learning how to overclockAnd the overclock to 4.6GHz is not worth it right?
yeah all looks fineimage of nvidia control panel:
Nvidia SLI section: https://gyazo.com/f8df1e56cc44877b8364aec0710fb6ec
GPU1: https://gyazo.com/8fe1402b9029d6b3e92b9821a081ffca
GPU2: https://gyazo.com/cfe64862148e4f6be7b885828e003148
GPU-Z GPU1: https://gyazo.com/719483ef6a3ba0fea9d4aa39f143a04a
GPU-Z GPU2: https://gyazo.com/e2d152774d7e417fb217ed460a1642bd
just wait. ryzen 3000 is coming out in 6 months. see how its performance is like.This new rig I'm thinking to go with 32-64GB of ram, rtx 2080 ti, i9 9940x cpu and asus extreme omega x299 mobo. What do you think?
4k hdr is expensive on the pc scene right now. you need to spend £2200 on a monitor lol. (asus pg27uq)So I'm stuck choosing a 10-bit HDR panel as there is literally none available right now.
yeah all looks fine
yes. if ryzen 3000 series is as good as rumours claim, then it'll be better/cheaper than anything on offer currently.You really think waiting till July/August to get a new build is a good idea?
no. if you want to get a new gpu now, then yeah, by all means. nothing on the horizon at the moment that would threaten the 2080ti's performance crown.A new nvidia card wont release by then to beat the 2080 ti will it?
2080ti is the first "true 4k gaming" cardEven buying the acer predator x27 now to go with my current rig will also be useless, as my rig cant handle 4K 60 fps at all otherwise I would buy that monitor now lol.
looks about right.And I have this link I found for my mobo and cpu regarding overclocking to 4.6GHz: https://rog.asus.com/articles/guides/guide-overclocking-core-i7-6700k-on-the-maximus-viii-extreme/
What do you think overall?
My sli bridge hasn’t arrived yet![]()
looks about right.
blame amazon...haha...
yes.And can one use an AMD cpu/mobo with an Nvidia card?
probably.would let me game in 4k now? Even though I only have 16gb of ram and an i7 6700k cpu?
yes.
probably.
well. 2080ti is already 5 months oldThey usually release their new line up of cards in the winter period.
well. 2080ti is already 5 months old![]()
leave the settings alone.But why in GPU-Z the PhysX box is unchecked when I set PhysX to the second gpu as shown in the image below in the nvidia control panel?
as long as it's enabled in nvidia control panel it's working. just probably a bug of gpu-zand also CUDA is not checked for the second gpu either which is odd?
