- 25 Mar 2004
- Fareham
What was?
The puddle outside!
What was?
guys need some help.
Got a 4 bed house where although i have all the trickle vents open on the bedroom windows were still getting condensation in the mornings and early evenings..
will any of these smaller units work if I stick it in the upstairs hallway or will they only work in individual rooms?
We had something similar in our old house, but the hot damp air was drawn into the loft, and it condensed on the roof lining, and fell on everything up there, saturating and ruining loads of stuff.
Well, it wasn't similar at all, because the machine I'm recommending draws air FROM the loft, blowing down in to the house.
Sounds like you had a faulty extraction fan/extraction fan pipe if your attic was being filled with humid air.
Should have explained better, the fan we had was piping cold air into the upstairs landing, there were vents in all the rooms that wen't from ceiling into the loft. The fan was moving air from loft to upstairs but it was creating a vacuum in the loft. Because the loft was sealed (no vent tiles) and insulation up to the rafters, there was very little cool air getting in, what was happening is the hot moist air was being pulled up through the vents in the rooms, cooling and then condensing on the roof lining.
Whilst this would be an ideal solution I really can't see it as being practical where the flat is a ground floor flat and the occupants are out at work all day every weekday.Open your windows, especially this time of year and its free.
Condensation is at best an inevitable consequence of humans going about their daily activity and putting vapour into the atmosphere which then condenses on cold surfaces. Ventilation will help where the outside air has a lower level of humidity than the indoor air.
