Already been decided the way brickwork is done means it's solid wallIf the wall is cavity, maybe water is getting in at the top and trickling down and soaking through.
If there's a slate dpc
Would have thought running your fingers over painted area you would still feel it?
Could the level of the soil have been raised over the years?
Happened to my step son
Some one raised the level of the pathway going down the side of the house for some reason or other
And it was higher than the dpc
LolIt's not as obvious as you'd think, especially if someone has also repointed it.
But this is what I am thinking might be the issue. People (who don't know buildings) mess around with them and cause problems. Of course, the addition of double glazing and sealing up houses hasn't helped these older properties but people aren't as 'ard as they were back in the day so need heating!
Yep good points
I am certain that internal wall has been replaced with plasterboard I suspected something about then when I purchased the house 5/6 years back.
This could have been a problem for a while and thats why the previous owner boarded the hallway, so I am wondering if there is a chance those plasterboards are waterproof already
Mr injector responded back telling me that he can’t help me under his gurantee as his team did not do the internal plastering work
Basically he is being useless
I suspected this would be the case
how long have water proof plaster boards been around?
I think it would be best to break that internal plasterboard up to see what is really going on before taking further action
but it is not a good time of year to do this right now as it will make the hallway extra cold and that’s the place I got my nest in.
I'm renovating a 1930's house and had issues with water under the floor when it rained.
Luckily as I'm renovating I could lift the floorboards, the root cause was perished mortar joints in the footings.
Only 2 or 3 tiny pinholes would let in a lot of water over a day! Tracing dye was invaluable.
Whats the slope of the property, would water accumulate against that wall in that area?
I note the damp tide mark is higher towards the return. Do you potentially have a dwarf wall under that return? Where water may pool up against it.
If you have a carpeted area nearby where you could lift a couple of floorboards and get your head in with a torch would be my thinking.
I'd do it after a decent rainfall if so.
My suspicions are that you have a cavity wall which is not allowing the walls to breath and release moisture outside. Because it can't escape outside, it's trying to escape inside hence the walls are cold because they are damp from the moisture trying to escape.
Try a dehumidifier for a week or two and see if things improve.
