OcUK Staff
- 26 Nov 2014
- Stoke
Now available, for at least the next hour due to the popularity - The mighty DAN Case. Available in Black & Silver, this is officially the worlds smallest gaming case in production. At a mere 7.25 litres, the DAN Case is not much bigger than a shoe box, but can house a 295/306 mm VGA card and SFX-L power supplies, with Mini-ITX motherboards. Due to the layout and component cooling, no fans are needed, and pretty much every bit of space is used intelligently to create a tiny case that can still pack a significant punch!
Stock is available now, but I would say order within the next 30 minutes or face losing out, as the next stock won't be available until June/July earliest!
DAN Cases A4-SFX Mini-ITX Gaming Case - Black @ £249.95 inc VAT https://www.overclockers.co.uk/dan-cases-a4-sfx-mini-itx-gaming-case-black-ca-000-da.html
The smallest gaming case in the world, created from premium aluminium in black, compatible with SFX-PSUs & Mini-ITX motherboards (Intel & AMD), dual-slot GPU up to 29.5 cm & 2-3x 2.5" drives
Only £249.95 inc VAT.
ORDER NOW
DAN Cases A4-SFX Mini-ITX Gaming Case - Silver @ £249.95 inc VAT https://www.overclockers.co.uk/dan-cases-a4-sfx-mini-itx-gaming-case-silver-ca-001-da.html
The smallest gaming case in the world, created from premium aluminium in silver, compatible with SFX-PSUs & Mini-ITX motherboards (Intel & AMD), dual-slot GPU up to 29.5 cm & 2-3x 2.5" drives
ORDER NOW
