Datasets - filling help
  • Thread starter Thread starter Pho
  • Start date Start date
Pho
Pho
18 Oct 2002
Derbyshire
I've managed to avoid touching datasets in the past and am having an awful time with them right now :o.
I need to manually fill the dataset and can't do it from SQL. It all works fine until I need to use a complextype.
I can generate sample XML from Visual Studio for this XSD which looks fine fine, I can use ReadXML() to read in XML in this format, and then WriteXML() it out to a file and again it is fine. I can't however find how to manually set the data.
My hacked together dataset fill looks something like this:
Code:
DataSet ds = new NewDataSet();
DataTable dt = ds.Tables["ReportData"];
DataRow dr = dt.NewRow();
dr["id"] = 999;
dr["children"] = {children}; // why can't I add children data? The column apparently doesn't exist
dt.Rows.Add(dr);
I can set the ID column fine. However, how do I gain access to the children column? There is a children table which is created, but I need to be able to nest the XML like below.
Schema:
Code:
<?xml version="1.0" encoding="utf-8" ?>
<xs:schema xmlns:mstns="http://tempuri.org/XSDobject.xsd" xmlns="http://tempuri.org/XSDobject.xsd" elementFormDefault="qualified" targetNamespace="http://tempuri.org/XSDobject.xsd" id="XSDobject" xmlns:xs="http://www.w3.org/2001/XMLSchema">
  <xs:element name="DataSet">
    <xs:complexType>
      <xs:sequence minOccurs="0" maxOccurs="unbounded">
        <xs:element name="ReportData">
          <xs:complexType>
            <xs:sequence>
              <xs:element name="id" type="xs:int" />
              <xs:element minOccurs="0" name="children">
                <xs:complexType>
                    <xs:element name="name" type="xs:string" />
                  </xs:sequence>
                </xs:complexType>
              </xs:element>
            </xs:sequence>
          </xs:complexType>
        </xs:element>
      </xs:sequence>
    </xs:complexType>
  </xs:element>
</xs:schema>
I think what I'm essentially asking is how do I create a children data table, and add it to the row at the same time I add the id number etc?
I'm using Visual Studio 2008 if it's any help.
Thanks.
