I got my family to send me one of these from the USA ,its an electric dust blaster for multi purpose use, I'll be using it for blasting dust and dirt from inside the pc as I'm tired of canned air although a lot of people are quite happy with canned air, I would prefer something like this as its something ive wanted for ages now.
It arrived yesterday and after speaking to a few friends that know a little bit about electronics (obviously they dont know that much
) they said it should just work if I either cut the american plug off and attach a uk 3 pin plug or use one of those plug adaptor things that you plug an electric shaver into (two pin) it should be ok and work.
So I tried shoving the american plug attached to the thing into one of the UK electric plugs that you would use to plug your electric shaver in, I gave it a try, straight away I noticed that I kinda had to force the two pins of the plug on the wire into the shaver plug as the american plug on the cable has two pins that are not exactly like an electric shavers two pins, but I was able to shove the pins in anyway even though I could tell they didnt feel like they were fitting proper.
Anyway, I plugs it into the wall, switched the thing on and for a micro second I got a jolt off the machine as if it was going to work, but instantly it stopped in that fraction of a second and then it done nothing at all and thats the way it is now.
I personally think I have maybe done something to the unit, but I pray I havent as even though I got it a lot cheaper from the usa it was still a bit expensive and now I dont know what to do.
I cant get my phone camera to work at present to show you some photos so the only thing I can do is show you screenshot of the item if thats ok ?
I know overclockers dont sell it, so I thought it would be ok to post the image, if not then "please" just remove image and "please" dont give me a formal warning or anything as I really dont see that I'm doing any harm in letting you see it and the details, thanks.
This is the item and the power details etc, really hope someone can help me please as I think and pray I havent blown it
Says on it "120 VOLTS, 60Hz , 4 AMPS, 500 watt motor, .75 HP"
and of course it has a 2 pin american style Plug on the Cable.
I dont see any switch to switch voltage and it doesnt mention a volatage switch in the instructions either.
Heres a screenshot of the item >
Hope someone can help me or tell me a cheap way to get this to work in the UK, thanks very much
p.s
I edited out the name on the machine etc incase its not allowed.
) they said it should just work if I either cut the american plug off and attach a uk 3 pin plug or use one of those plug adaptor things that you plug an electric shaver into (two pin) it should be ok and work.So I tried shoving the american plug attached to the thing into one of the UK electric plugs that you would use to plug your electric shaver in, I gave it a try, straight away I noticed that I kinda had to force the two pins of the plug on the wire into the shaver plug as the american plug on the cable has two pins that are not exactly like an electric shavers two pins, but I was able to shove the pins in anyway even though I could tell they didnt feel like they were fitting proper.
p.s
