Honestly, I tried so many different recipes that suggested boiling the potatoes first, either in water or the milk/cream recipe and there's absolutely no need! You're just creating washing up and work. We've had far superior results by just sticking them straight in the oven. Agreed about the mandolin though, you do need to cut them as thinly as possible!Nigella knows her dauphinoise
http://www.nigella.com/recipes/view/crafty-gratin-dauphinoise-2254
a mandolin really helps, well worth the purchase if you have this regularly
Yep good advice; they stay hot forever! Also, I think most restaurant dauphinoise are twice cooked. They cook a big batch/dish of them and let them cool. When they're completely cold you can cut them up into the nice neat squares then just reheat them. That's the way to do it if you're trying to impressMy advice would be to allow enough time for them to cook. You can keep them warm no problem (ie start too early) but the number of times I have tried to serve raw potatoes to guests is bordering on embarrassing.
Used a mandolin to slice the potatoes up as it saves a lot of time.
real dauphinoise potatoes do not have cheese!
