DBAN possibly killed hard disk
Permabanned
4 Apr 2009
Not sure which forum to put this in...
I zeroed the hard disk of an old laptop using DBAN. When it finished it told me that it completed with "non-fatal errors." Now when I try to install XP it tells me that it can't find any hard disks. I booted the DBAN disk again, and it can still see the hard disk and write to it. Any ideas why XP can't?
Note: I've never installed an OS on this machine myself so it could possibly be XP.
Could be that your BIOS is set for the SATA to run in AHCI mode which XP can't use by default. If so you'll either need to change BIOS so SATA is IDE mode or supply Chipset drivers on usb/floppy by pressing F6 when XP setup asks for them.
Yes, you're right - it was set to AHCI mode.
D'oh!
