new rig?
hi. im thinking of biulding a new rig. these are the main components.
MSI 790GX-G65 AMD 790GX ddr3 Motherboard
AMD Phenom II Tri Core 2.8GHz
G.Skill 3GB (3x1GB) DDR3 ram
Asus ATI Radeon HD 4890 1GB GDDR5 PCI-Express Graphics Card
Corsair VX 550W ATX Power Supply
will this all fit together well? i will upgrade the ram later to as high as 12 GB if i can afford it. using the same type. dose this look good? what is the weakest part? thanks
