quite new to overclocking but this issue is related to my DDR 4 ram  -Dark Pro 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz -  on task manager it says 2133mhz and cpuz  1064.1mhz , hardware is, gb ab350 gaming 3  - Ryzen 5 1600, gx1080ti    ,  bios updated to F10  , disable all - core performance boost ,amd cool+quiet, SVM MODE Global C-state control /   X.M.P ( but I have tried with this on too enabled )
things on auto . power supply idle , opcache control , downcore control , SMT,)
Dynamic vcore dvid +0.075v
Dynamic vcore soc +0.264v
Dram voltage 1.340v
system memory multiplier 32.66
memory Frequency 3266mhz
memory timing mode manual
profile ddr voltage 1.20v( in grey
channel interleaving auto
Rank interleaving auto
channel a and b timings
16.16.16.16.36 for both ,
I noticed on the DDR ram label it has four number instead of five to input , 16,16,16,36 so I just added in another 16 not sure if this is right to do . changed the voltages a bit but still not had any luck , I noticed on saving bios when it resets it goes off and on about 4 times before loading up so I think its changing something back .
Dram voltage 1.340v
