DDR2 SODIMM Problem?
16 Dec 2009
Hey everybody.
I currently have a ddr2 laptop that has 2 x 512mb 677mb sodimms inside it.
however the ram is only running at 266mhz and not 333mhz
which using the double date rate
266 x 2 = 532mhz (533)
333 x 2 = 666mhz (677)
why isnt my ram running as fast as it should be ?
cpu-z says my fsb to dram ratio is 1:2.
could it have something to do with my cpu fsb? thats at 533mhz...
before i have used 677 with no problem tho.
any ideas how to sort this?
It could be that your RAM can't run at higher speeds with the CPU, happened to me.
I had to decrease RAM frquency and in effect making Timings better.
oh my bus speed is 133mhz so dram ratio to fsb is
fsb 1:2 dram
so ram is running at 266mhz
so 1:3 would be 399...
so i need 1:2.5 ratio eek...
