hi guys
few weeks ago i bought an MSI P35 Diamond B Grade (tested and working
) for 12p but as far as I am aware it only takes DDR3 800/1066/1333.
This leads me onto my question, and I am on a tight budget too .. what RAM do I buy for this mobo? Are there likely to be large cuts for ddr3 when nehalem surfaces? When will this be? I really only want to spend about £60 on the RAM in all honesty so do I just go for the cheapest 2GB set of DDR3?
thanks
) for 12p but as far as I am aware it only takes DDR3 800/1066/1333.This leads me onto my question, and I am on a tight budget too .. what RAM do I buy for this mobo? Are there likely to be large cuts for ddr3 when nehalem surfaces? When will this be? I really only want to spend about £60 on the RAM in all honesty so do I just go for the cheapest 2GB set of DDR3?
thanks
