I am looking to build a fresh ITX build over the next few months and wanted some advice on which of the above would be the better option as they both have similar costs? With the ITX boards only having two DIMM slots it will be set and forget as i do not intend to upgrade before a complete system refresh
PC will be used for general browsing and gaming (MMO, FPS, RPG etc) The rest of the specs are dependent on reviews for the new AMD gear but chances are it will be a mid/high end mobo, 3700x with a 2070 or something similar. Monitor at the moment is 1080p 60hz, but looking to go 1440p or 144hz reasonably soon
Many Thanks,
Technics
Many Thanks,
Technics
