De Frag a HD
20 Sep 2005
Wilderness of ESSEX
Hi every one, :)
Can any one recommend a de Frag software which is better than the standard XP one, and off course where i can get it from.
i have checked the OC software section and there is none available to purchase.
many thanks
OO Defrag. Google it. I like it because you can defragment several hard drives at once (MS one doesn't do this) and it has a stealth defrag which hardly hogs the system, unlike full defrag.
Ive tried several including those mentioned and VoptXP is the fastest by far. I recommend that because defrag has to be convenient or your never bother doing it regularly
ATIorNvidia said:
Diskeeper or Vopt XP r good defraggers, google it and you hould find a download
Thanks people, i did not know there was a large choice.
I will Google the said mentioned Defrag soft ware when i get home from work.
Many thanks
PS. I have had a look on web, and price is apx £25 for Diskeeper Vr 10 Home edition. Is that about the right price ! ?
Quite a lot of them offer 30 day trials - so download them all and give them a go - not only will you get free defrags for a couple of months, but you can decide for yourself which you like :D
Best advice! I tried to do this but stopped on the 1st one - Diskeeper ;)
Love it, but it's probably time to do the rounds?
There is a school of thought which says that defragging disks is a waste of time for most home users as it does little to improve the performance or lifespan of the disk.
I'm rather an agnostic on this issue. I do very occasionally run Windows defrag, more out of boredom than expectation. But I only use my computer for games, TV, the internet, word processing etc.
I would strongly dissagree! :eek: Most 'light' users can get away with an occational defrag' but it is still an essential if you want a fast machine. The first thing I do when somebody has a 'problem' with their machine is scan the registry and defrag the HDD. These two simple tasks often require overnight runs as they have not been carried out for years :rolleyes:
i attempted adding 4000 songs to my music library ( dbpoweramp ) after a fresh reformat and install.
was going at about 100 songs a minute when adding.
So i defragged the disk ( all the music files are located under the same folder )
it then flew, and took a minute for the lot
I concur & another vote for Diskeeper ;)
Diskeeper. Defrags in double quick time & gives you a graphical representation of how degraded your drive is against how it will be post defrag :)
