De-lurking for advice - itx gaming system, ~£700-750
My SG-05 build (see my sig) sits on my coffee table next to my 47" panny.
Personally i wouldn't put it on the carpet mate, it will attract all kind of fluff and dust etc. Stand it on something if you can.
Depending on size, may cram onto existing TV unit...
Yeah, makes sense actually, PSU will Hoover up from underneath.
Might get that b grade effort to get a bit of space gains on the innards.
Got the SG07 in the end, think that is on the bottom. I can re-arrange some things in my front room cabinet to make it a centrepiece now though! Just need to buy some of the bits mentioned in the lists above to finish it off.
I have been told to pick myself a gift to the price of £30 so I'll start with that passive cooler. Assuming you can use it fanless anyway.
In fact, after scanning through threads on here, I'm not sure the cooler that was mentioned on one post above will even fit. So will go stock.
