Hi all, having some hard drive troubles and just wanted to make sure that it's the drive that's gone and it's not somehow savable. I've had good luck with HDDs in the past so this is all new to me.
Basically I put a new build together and all looked to be well but the drive seemed to me to be louder than it should be, certainly louder than the four year-old Seagate in my previous system. Bizarrely, it seemed to get louder the further I overclocked my e6600 (which wouldn't go over 370fsb on a P5WDG2 Pro, but that's another story..). After spending all day installing and tinkering I went to make a new partition with Partition Magic for Vista, the PC rebooted to finish it but now Windows wouldn't load, reboting itself on the XP loading screen.
I ran a level 2 test with Spinrite which found unrecoverable sectors, but after doing it XP was loading again - except now occasionally it will freeze up or reboot. Seatools doesn't seem to show any problem, but I ran Spinrite again - on level 5 this time - and although it showed no unrecoverable sectors this time it did come up with nearly 2 million seek errors.
This could be normal for all I know, so is the drive definitely borked? I don't want to go through the process of returning the drive if it's just going to come back with them saying it's fine, just a file system error or whatever. And if so, does anyone know if I'd be better off returning it to Seagate or to OcUK?
Thanks a lot
Thanks a lot
