- 26 Jul 2010
- Wiltshire
A decent battery should be 12.6-13.2v with the car at rest. With the car running, head lights on full, rear demister on & the heater blower on the voltage should be no lower than 13.5V (ideally the alternator runs at about 13.8-14.2v with no accessories on).
But.....
A multimeter won't tell you the full story. A battery can be 'good' voltage wise, but be unable to provide a decent amount of power when trying to start the car. You need either a hydrometer for a low maintenance battery or a proper battery load tester for a sealed battery.
The poor man way of doing a load test is to pull the fuse from the fuel injection & crank the car for around 5 secs while watching a voltmeter attached to the battery, it shouldn't drop much below 10-11V.
*edit to add, I find an awful lot of good batteries at the local tip. If a battery becomes discharged, especially one that's lived on a car for several years without ever having a charge from the mains, it should be trickled charged for 24 hours. I've had supposedly dead batteries come back to life after a decent maintenance charge from a dedicated charger. The alternator on your car is far inferior in comparison & won't charge a flat battery correctly - it isn't designed to.
But.....
. Car will turn over a lot easier with a bigger battery, don't worry about it 'frying' the starter or anything as it only pulls as much current as it needs, the bigger battery can't suddenly blast it like the emperor from Star Wars lol.
