So to cut a long story short ish
Decided to rebuild my system with a uses asus sabertooth p67 and a 3570k (used)
Built the system and couldnt get anything to work, long and short of it was it needed the latest bios update for that cpu.....so i got hold of a rev2 cpu which booted fine and got windows running etc
Took the rev2 out and installed the 3570k and cleared cmos etcetc. Now system dumps memory on every single restart. fault finding says that its a ram issue. all slots and ram working fine before the cpu switch.
Reinstalled the i3 rev2 and i can get back into windows but now displaying as having 4gb of ram and at 1333 not the 1600 as per the ddr3. <it was showing this with the rev3 cpu in bios.
Cant boot with the 3570k at all but the i3 rev2 works fine appart from the ram displaying 1333 and 4gb (bios can see all 4 slots and displays them all at 1333hz but only give me 4 of the 8gb in the main boot window and in dxdiag)
is the cpu dead?is the mobo now deadish? will this saga ever end?
