Hey all...got a problem i need sorting soon please!!
Well ill just get straight to it, the damn thing wont turn on! It goes to boot, fans spin, then all power just stops! the pc turns off, and then starts up again, then dies off...repeat.
I have tried it with no ram in case thatw as the problem, i get a load of beeps, but the same restarting thing still happens.
I have reset the CMOS like 5 times by using a jumper over the two pins, and once by removing the battery. I also used a screwdriver the first time on the pins just to short them out (which i have done before with no problems, so i dont think that could be the problem?)
Is this a common, or even fixable problem? I was overclocking my E6300 a fair bit so im not sure if i did kill it by doing that
When it boots then shuts off, there are NO post beeps, unless as i said above, i remove the ram.
Please help ASAP! Thanks, Adam
