Hi guys,
I'm not sure if it's my cpu or vga card that's the problem so am posting this in both forums- hope that's ok?
Anyway, specs:
E6600 --> Q9550 E0 Stepping
Abit ip35-e
corsair tx650 psu
gtx470 twin frozr
4gb kingston hyperx 8500
Win 7 Home Prem 64
Problem:
So I have been using an E6600 cpu @3.2 for a couple of years and bit the bullet on a used q9550
Having read up about the issues with the mobo and this chip (not posting) I was a little anxious but successfully flashed the bios to version 18beta which was supposed to work and it did! *joy*
I checked in the bios and again all was well.
Booted into windows and checked cpuz and speedfan. Temps were fine.
Before I know it horizontal artifacts appeared all over the display and moments later the computer froze.
I have rebooted the several times and each time got the artifacts.
I have checked both power cables were in place and reseated the card.
Now, I know that the cpu cannot affect the vga card but it just seems a massive coincidence that so soon after changing the chip the card should go.
So much that I tried another chip that I had bought, convincing myself it would work; it didnt.
Looking in the device manager I have an explanation mark next to the device and in the device status it reads "Windows has stopped this device because it has reported problems. (Code 43)".
I have deleted the drivers, redownloaded the current ones and reinstalled. Same problem.
Now, I'm not sure if this is relevant but looking at some screenshots at work the atifacts are not on them. Is this a telltale sign of anything??
I will be trying out another card tonight that will hopefully proove the problem but if you guys can shed any light that would be great!
Cheers.
edit.. incidently, when I first installed the 470 a few months ago the very first time I booted I got the artifacts then and it froze. After one reboot all was well and has been until this day.
edit2.. the artifacts apear right from the abit splash screen, but not in the bios. Also windows always wants to know whether to start in safe mode or last known good etc, so clearly in not happy.
Anyway, specs:
Abit ip35-e
corsair tx650 psu
gtx470 twin frozr
Win 7 Home Prem 64
Problem:
Cheers.
