Dead PSU?
8 Oct 2010
Purley - Croydon
Hi,
After re doing my rig yet again, the mobo lights and aquaero screen all turn on, but the system refuses to start. Even when the PSU is bridged, nothing happens :(
I've tried sticking a Corsair 600w in my system and that works with no problems at all (no hardware ones anyway...). Is there any way i can test for certain that the PSU is dead?
Thanks
probably but to be honest there are that many cables to check, it ends up being a pain, iv tried in the past
So could it be that it's one cable that's causing the problems, but the rest are fine?
ie, could the 24 pin be fine whilst the 8 pin is faulty?
yup, iv had it where its just the 5v line for instance, or the 12v, i have come across a few different scenarios
ah, **** :/
But if the PSU doesn't allow itself to be turned on then surely there's no way it could be functional? Or am I missing something?
yeh it can still power some things but not the pc itself or the other way round, you would be surprised what issues they can cause the mischevious little sod's
Thanks for that :)
I shall see to getting it RMA'd
What's the best way to prove it's 100%, never going to come back from the grave, dead before sending it back to a retailer seemingly notorious for rubbish RMA?
well dont damage the security sticker for starters.maybe power it up with the paperclip method with a nail etc stopping the fan from spinning and fit an old high power 4 pin fan .leave for a few hours,should cook the insides nicely
dont complain if you get electricuted though :-) :-)
Tried bridgin it already and it doesn't turn on :(
