Dead S3...
21 May 2010
Digbeth
My S3 died last night. Stuck it on charge, under my pillow, like every other night. Woke at 1am to it very hot and stuck on the boot screen. Read around the net, deleted all data etc, tried a new firmware with ODIN, tried re-partitioning it, everything. Phone is dead, I can't boot into Recovery, I can only get onto 'Download' and even then ODIN won't work it's magic. When trying to stick a firmware on, ODIN hangs at "NAND Write Start" and when I try to re-partition it fails...
I think my phone has SDS...
Charging a battery under a pillow. Genius, pure genius. You overheated it, something in there is now caput.
I don't believe charging a phone on a pillow would kill it, it gets far warmer playing games etc. Sounds like you've tried everything so I would send it to Samsung
I have tried charging my phone under a pillow before. It does get hot and I never did it again. It may be fine to do once in a while, but seeing as you did this every night, something inside the phone finally gave in. Send it back for warranty repair.
You loved your phone so much you slept with it...?
Take the battery out and leave it for a few hours, then try get into recovery again.
Took phone into O2 today, they had a look at it and tomorrow it is being sent to Samsung for a warranty repair or replacement...
I highly doubt charging it under a pillow would generate enough heat to damage it. I've left my S3 in the sun for a good few hours before and it's been fine.
Agreed. Whilst charging your phone under your pillow is one of the more weird things you could do with your phone I doubt it would be responsible for its demise. More likely just bad luck.
Poor little S3...You murder it..:(
Hope you also put the electric blanket on to make sure it didn't suffer for to long and died quickly..
