- 7 Oct 2008
I use a Nova Winner 3 mat, which works very well
Don't think OcUK stock 'em anymore though.
Don't think OcUK stock 'em anymore though.Guys i need ya help. How do i get access to my mouse's advanced functions? the tab doesnt expand in the razer control panel?
compared the DA to the G5:
Glide: G5 is the winner in my books. the Da i think hasnt got enough glider space on it but the G5 is just right, altho it has a slight balancing issue on the right.
Feel: I will say thought that the DA does feel gr8, im using my old 1 at work and i never have any problems. However, the g5 has a stupidly designed right side, theres a dip in the middle side of the right which makes it feel uncomfortable when using it for the first time. however over time you get used to it, but it is still a pain.
Software: Very....VERY slight advantage to the DA, found it easier to use. However the logitech software is very unique.
Effectiveness (overall ingame performance): Althought the feel and custimizability of the DA wins in those areas, the G5's ability to be gr8 at any game type (i usually play TF2/GTA4/L4D/L4D2/CSS) i feel a lot more accurate with my shots and the pin point accuracy is slightly improved with the G5.
Overall Preference: G5
Althought i absolutely adore the DA, the G5 just performs better in my POV. the DA does look better as well if your setup is mostly black with a matching keyboard and mouse. but you cannot go wrong with either mouse, any will do!
I have the Deathadder guild Wars Edition:
It matches my Saitek Cyborg, and orange Acer G24 monitor![]()
What driver version & firmware are you using dmx?
(I did, and my god this mouse is awesome)
One thing you missed (as did when refering to my G9) is the cord. I hate it (on the logitech). Any one else feel the same or just me? The DA's cord is much better imo.
ive got a copperhead and its beginning to do my nut in
I bought one of those not long ago to replace my original model (1600dpi) diamondback after it's button went dodgy, I was disappointed with it compared to the old diamondback.
It just doesn't feel as responsive, always seems to be a very slight bit of movement lag and it "twitches" really badly on most surfaces, even though it uses a laser instead of an LED. It also doesn't feel as comfortable or as solid either.
So I decided to fix the button on my diamondback and went back to using that![]()
