Deleted User 298457
Deleted User 298457
The trigger sport black bait(?) front wheel has a big bulge where the sidewall has given way. Disappointed given it has hardly been used. Anyway, is there a recommendation? It is a 700x38c (38-622) - I have just bought a 700x30c inner tube (is that right?).
Thanks.
Thanks.
) and it went bang around 95psi...
I would expect a 38c to be somewhere in the region of ~50psi at a guess? A 25c would be max of 100psi, my 32c touring bike has a max pressure of 75psi. The maximum pressure should be on the sidewall of the tyre.
