I've tried expensive h phones and can't tell the difference between them and cheap ones. Spend £25 at the most!
I’m rocking Astro A50’s (Gen3), best I’ve ever had, can be used on pc too at the flick of a switch. Bit pricey though
You can get grade A refurb Gen3’s for £150, 12 month warranty included and they’re as new, that’s how I got mine. Never had an issue, 4 months in
Can you please tell me why you are not recommending the? I am using the same ones for about a week now and they seem great. I don't want to feel like I am missing out on something even betterKingston HyperX Cloud 2. Can't recommend them enough.
Can you please tell me why you are not recommending the? I am using the same ones for about a week now and they seem great. I don't want to feel like I am missing out on something even better![]()
Ok, I am officially blind. I read that he wrote "can't recommend them though" instead of "enough". FML Thanks CHokKA dudeHi Marko
He's meaning that they're so good, that no matter how much he recommends them, the recommendation won't be good enough because they're such a good headset. It's a positive thing![]()
BTW, yeah, I find the HyperX Cloud awesome too so there goes my recommendation as well![]()
I used the arctis 5 wired, I have the exact same comments - they are awesome for the price but really low amount of vacuum and noise cancellation, that's why I switched to hyperx.i have the steel series arctis 7 wired, great for the price!
