Decent ipad car charger
2 Dec 2004
Under The Desk, Wales
I will be going on a long holiday soon and wanted to buy a decent car charger for my ipad. Can someone recommend a good one? Thanks
It's an iPad 2
First and cheapest option is to get a cigarette lighter USB power thingy that's rated up to 2A. You can pick one up for around a fiver.
Alternatively, get an inverter. £25-30 will get you a decent enough one. The one I got is rated up to 300W and allows me to use any standard mains chargers plus also has two USB sockets, one 1A and one 2A. More expensive but more flexible as it allows you to use non-USB chargers for things like laptops or camera batteries.
Still need to know which one to go for as several available and some reviewed are terrible. Cigarette lighter one id fine but which one? Ta
Yep, used it last weekend at Le Mans. It's rated at 2A so will charge an iPad pretty much as fast as the mains charger does.
<hijack>How funny - Audi-sport!</hijack>
<back_on_track>I'd suggest an inverter too.</back_on_track>
Been using a cheapie couple of £ dual USB charger from the bay rated iirc at 3.3a charges box my ipad and I phone fine and is working fine after a few months non stop use
