Decent USB-C for Oculus Quest 2?
20 Mar 2004
Trying to help out a family member connect his Oculus Quest 2 to his PC.
Watching some guides saying he needs a USB-C to USB-C lead, but that it needs to be good quality to avoid any problems.
Can anyone recommend me a good 5m+ cable?
It can be a USB A to USB C. Depends on what you've got on your motherboard. What's his system?
Also, does he have a half decent wifi setup? Might be easier to just use airlink. Certainly nice to be able to play without wires if you can!
What does he need to connect it via cable for?
You need really kick ass WiFi to run pcvr wireless on the quest. For many people using a usb cable will give a much better result
WiFi is great if you can use it however. Amazes me really just a few years ago it was a £300 add-on to use pcvr wireless now it's a free over the air update
I'm 90% of the time happy with WiFi 5, moving house next month and isp provide a hub with WiFi 6, op's family member would be better off buying a WiFi 6 box, then have a cable plugged in, wireless is massively better
