Been after a new case for a while, as my current case (NZXT Hush) doesn't have much air intake and I think is the cause of some noise problems I've been having (PSU gets very noisy under load, and I think it's cause it's being starved of cool air).
The three cases I'm currently looking at are the BitFenix Merc Alpha, Merc Beta (currently out of stock, so may not be an option), or the Outlaw.
I've read that the Merc cases have partially blocked air intakes on the front, so I'm concerned that they may have the same issues as my current case, although they do have various other places for mounting fans so perhaps using one of those would overcome the problem.
My specs are:
Q6600 (At stock 2.4Ghz, with a Freezer 7 Pro)
GTX460 768MB
2x Hard drives (Not SSD)
1x DVD RW
Corsair 500W PSU (Not modular)
If you have any other suggestions for cases around the same price or only a little bit more then I'm happy to listen. I'm looking for something fairly quiet though. I also need something with USB 2.0 rather than 3.0, as my motherboard is old.
My specs are:
GTX460 768MB
1x DVD RW
