- 12 Apr 2013
Hey everyone,
So at the moment I'm using a couple of cheap 16:10 monitors (mismatched, but the same 23" size) and I'm looking to definitely upgrade within the next month or two.
I wish to have a triple monitor setup, and intend to play games as a major part of this (competitive League of Legends and CS:GO primarily, so low latency is key). I also would prefer the size to be at least 27" for all three.
Now, whilst I do like the idea of having three of the same monitors I would like to see what you think about having the primary (center) monitor as something designed for gaming specifically, such as the Asus PG278Q ROG Swift 27" G-Sync 144Hz and then have a less expensive, however still high quality monitor on each side of this.
OR I could just bust my wallet out and buy three of the above, but considering I would only really use one for games (the other two for webpage refrencing, skype etc.) it may seem like a waste of good hardware.
Alternatively I could just get three really nice looking displays that are still perfectly fine for gaming, but that's something I would appreciate input on in regards to choice.
It's probably worth pointing out now that whilst there is no upper budget, I would still like to be worth the money paid of course. Also that I'm running a machine with a GTX 980 so compatibility with higher resolutions would also not be an issue. -although I still wouldn't want to go above the 2560x1440 mark, nor would I like non-standard monitor aspect ratio (so let's stick with 16:9).
So please do let me know what you think, I would highly appreciate it.
Thanks.
Thanks.
