Thanks Gaidin, I thought you were running 1.200 vCore from the first shot, but at 1.287v it's pretty much bang on what I have at the moment.
In terms of the H50, certainly is a lot neater and tidier and I will consider one for my next build - from a temperature perspetive, it doesn't stack up for me to switch to one of these at the moment though.
Some good info here guys - it will come in useful as I try to optimise mine. Thanks for sharing
how did you get your icons on the top of the page davy that looks m8
I never thought I would have seen that much of a difference between AS5 and this stuff, but I was wrong.
I will be using MX-3 from now on.
It has a really weird consistancy compared to AS5 to, it is quite pastey, and really easy to apply to.
Before applying this stuff my loads were around 82c, now they are down to 77c on the hottest core, really can't fault this TIM at all.
I'm using Rocketdock mate.. find it much tidier having that rather than having icons on the desktop.
@ChillZ my D0 needs quite a bump in Vcore when I have it at 4.2GHz as well, not quite as high as yours, but it's still quite a jump from what I need to do 4GHz.
3.8 Ghz with a Noctua. Temps from Everest on a warm day.
Idle 44C - Everest stability testing ~78C, Gaming ~50C
What you running Vcore @ for 4.2@ My temps at 4.0 seem good so thinking of a 4.2 now my paste has cured.
Mine is the same, albeit ive only got it running stock at the minute, idle temps are, 29-23-29-23, also using mx3 with a TRUE and 2 400-1200 rpm fans currently running at 1020 rpm.For me, core 0 and core 2 are the hottest ones.. I see a 6c difference now between core 3 and 0, it used to be 10c when I was using AS5, but after I applied some MX3 it dropped to 6c, though I assume this is probably more to do with reseating the HSF than anything else..
I think the only way I could get them to even out more is by having my HSF and chip lapped, which I'm not going to do!!!
