- 16 May 2011
- Staffordshire
Ok, so my brother brought to me his WD Passport 1TB external hardrive and says the USB connector is dodgy, can you fix it. When i say its broken, what is happening is i get a flashing lite on the drive itself, disk manager crashes when the drive is attached, my computer shows a drive with no name or capacity and does not open. So i opened it up expecting to find a SATA connector and thinking an easy fix. Instead what i find is no SATA, the broken USB and some pins.
On the left is 12 pins over two rows. On the right is just 2 pins.
If anyone has any knowledge of this then your help would be greatly appreciated.
Are the pins of any use? Or is there any other way you can suggest to get the data off the drive?
Or am i wasting my time?
Thanks
Thanks
