- 22 Jun 2018
- Doon the watah ... Scotland
Just dont expect SSD performance basically ... expect HDD performance!
Yes, they plug in, the appear to Windows as another drive and will take the next available drive letter (unless you specify one in particular). The only word of caution may be that some USB controllers on very cheap devices may not be that great for sustained transfer of data, but bigger brand makes will probably be fine.
Any reason why you cant fit an HDD into the machine itself ? Even ditch the 2 SSD's and replace with a single larger one, then add a 2.5"hdd into the machine instead ?
