DELETED_5350
I am not sure which comparision you want to make.
For example, a 80Gb WD IDE drive with 8Mb cache is ~ £37.
For only an extra £30 (at ~ £66) rather than the extra £60, you can get a 250Gb WD SATA II drive with 16Mb cache. That would be worth it for me.
Also, Seagate have a 300Gb SATA II drive with 16Mb cache for £81.
There are others to choose from.
Ultimately, only you can answer that question.
I would tend to go for the SATA II 16Mb option - that's what I have done for my last 2 hard drives. You are not likely to notice much speed difference, if any.
