Delidded, paste longevity?
27 Mar 2009
I delidded a 4770k I picked up cheap and didn't give the paste to much thought. Just wanted to use something non conductive to avoid any disasters.
I've used noctua nt-h1 and initial temps are much better. A good 20 degree drop but now I'm starting to read that these sort of temps only last a few weeks with paste due to "pump out" and temps soon start to rise.
As delidding has been around for a while now what pastes have you guys used and what has their longevity been like? Don't fancy redoing my paste once a month.
I didn't stick the IHS back down either, just removed the sealant and clamp it down with the socket clip.
I used both CLU and CLP for delidding both an i5 3570k and an i7 3770k and the stuff was good for a year and even then I re-pasted cause I wanted to rather than actually needing to do it.
Once a month sounds a bit excessive, but some thermal pastes do degrade over time.
A few people use liquid metal type TIM between the die and IHS (after insulating any resistors / contacts around the die). However the jury is still out on how safe that is in the long run.
See how temps are after a month with the noctua paste.
If it suddenly starts getting hot then buy some CLU/CLP
