Only thing to be aware of is that only the A04 revision can do 1:1 pixel mapping on 1080p sources so, if you have an earlier revision, you'll get some scaling.
Only affects digital input via DVI I think. Revision is printed on the back of the monitor and the original box.cool never used composite before.... how do you tell the revision ?
just had a quick look - theres a 1-1 option greyed out... guess this is only available via composite ?
HDMI cable from PS3 -> HDMI Cable into HDMI/DVI conversion -> DVI cable on output of convertor to Dell 2407Marky (or anyone else)
How did you connect the PS3 via HDMI-DVI? Im getting nowhere with mine at the moment (getting coloured noise/snow) and either its a bad cable or me jsut not setting up the correct setting on the PS3/2407WFP.
I do have an A04...
ps3ud0![]()
Whats the settings in the PS3 and does my experience here sound familiar?HDMI cable from PS3 -> HDMI Cable into HDMI/DVI conversion -> DVI cable on output of convertor to Dell 2407
Thats the way I have it and it works fine![]()
