Dell Disc errors 2205/2305/2310 Systems fix here
8 Jan 2009
Northern Ireland
Issue:
Disk Check error with 2205/2305/2310 Systems
Description:
On a computer that is running Windows 7, you use the Chkdsk.exe program to schedule a disk check during the next system startup. However, the disk check does not start correctly. Specifically, you may experience one of the following issues the next time that you start the computer:
A countdown timer is displayed and you are prompted to press any key if you want to skip the disk check. However, after you press a key, the countdown timer continues. Eventually, the system may stop responding at the count of 1, or start without performing the disk check.
The countdown timer is not displayed and the disk check starts immediately.
The countdown timer is displayed. However, the disk check starts before the countdown timer reaches zero.
Running PSA wont detect any errors with the HDD, as it’s an OS issue. (OS Issue only if the problem description meets the above)
Microsoft has confirmed that this is a problem in the Microsoft products
Windows 7 Enterprise
Windows 7 Home Basic
Windows 7 Home Premium
Windows 7 Professional
Windows 7 Starter
Windows 7 Ultimate
Solution:
A supported hotfix is available from Microsoft. However, this hotfix is intended to correct only the problem that is described in this article. Apply this hotfix only to systems that are experiencing the problem.
For further info on the problem read the Microsoft Article here: http://support.microsoft.com/kb/975778
To Download the Hotfix CLICK HERE
