Dell HD replacement
28 Feb 2006
No longer riding an Italian
Hi guys,
A mate has given me an old Dell Latitude PP01X to fix, the hard drive is failing; the BIOS often reports no bootable devices found and it is prone to start clicking – from past experience with desktop drives, this is a sure sign of failing.
Anyway, onto my question: I have often thought (rightly or wrongly I don’t know) that when it comes to replacing hardware, Dell is a bit questionable – only working with certain parts etc. Now, this to me sounds unfeasible, but after working in IT for years and hearing stories, I don’t know what to believe.
I need to know if I can simply swap this drive out with another, or will I need to try for a like for like?
Btw, the current drive is an IBM Travelstar 48 gig 5400 rpm (model IC25T048ATDA05-0).
Cheers,
Scort.
Thanks for the confirmation, I did suspect the stories weren't entirely 'accurate' :p
It's a notebook btw, so I'll take a look at the 2.5" range from OcUK.
Scort.
The BIOS issue is unlikely unless you get a drive bigger than 137GB (in which case any issues may be fixable via a BIOS update). Swapping laptop drives tends to be a bit fiddly but I've done it successfully on two old laptops (one of them a Dell) and had no issues on either.
