- 10 Jun 2010
- Scotland
I have a dell XPS where the PSU went bang on it as they do. I ordered a new PSU only to find the fittings are custom to Dell, so you can't use any other PSU with the case as the screw holes don't align.
I decided to order a new case. Only to find when stripping out the motherboard that the front panel headers are well.... not quite normal!
It's one big long strip and has a custom cable from the case.
Is there anything I can do to modify this in anyway. How is it possible to hook up the front panel connectors to a new case?
P.S. I deteste Dell. Just another reason why no one should ever ever ever!!! buy an OEM computer... EVER!!!
