Dell Power adapter issue
14 Sep 2005
All over.
I've got a Dell 13z. When it is plugged in it doesn't recognise that there is a power adapter and instead continues to discharge the battery. The blue light on the cable leading the brick is on.
The only way I've solved it is by removing the battery and turning it on while plugged in, then turn it off and put the battery back in.
Is there something wrong with the power adapter? Or could it be a software issue?
