- 15 Feb 2011
- Slough
believe me, theyve got performance to match the price tag. they are pretty much the best cases for air cooling your going to find.Thanks Jony,
That Raven 2 looks "classy", but has a price-tag that suggests aesthtics over function?
also, in answer to your question that i cant be bothered to copy the quote for, there are only a couple of main changes between the raven 2 and 3 aside from the looks.
as you might have noticed already, the raven's motherboard has been rotated 90 degrees so the graphics cards and motherboards back panels face the top of the case (great for airflow).
the PSU on the raven 2 is at the very back of the case, whereas the PSU for the raven 3 is where the hard drives usually go. this means that the raven 2 is quite a bit longer than the raven 3
the hard drives in the raven 2 are in their normal place, but in the raven 3 they are behind the motherboard with all the cables. this is actually quite a clever place to put them as there is still plenty of room for masses and masses of cable spaghetti back there
the last main difference that comes to mind is that the window on the raven 2 is on the right hand side of the case, whereas on the raven 3 its on the left hand side of the case (the normal side). this is obviously because the motherboard is mounted on different sides of the case on the raven 2 and 3
however, whichever one you go for you'll get a fantastic case
