Hi there
We have stock of this new E-IPS 24" with LED backlighting due in next week, were also bringing onboard their professional TN panel as well with fully adjustable stand:-
Dell UltraSharp U2412M 24" Widescreen LED Monitor - Midnight Grey @ £299.99 inc VAT
Enjoy widescreen performance, any way you want it. With a 24" 16:10 panel, IPS technology and LED backlight, the U2412M provides a brilliant view, plus amazing adjustability to suit any style. Powerful:
- Experience IPS technology, featuring a wide viewing angle with high-quality color representation for a peerless viewing experience.
- Flexible: Pick the view that works best for you with an almost unlimited range of tilt, swivel, pivot and height adjustments.
- Customizable: Change your energy usage settings, text brightness and color temperature with the touch of a button to help conserve energy with this eco-designed arsenic-free and mercury-free panel.
Whether for work or for play, the Dell UltraSharpTM U2412M can deliver an unmatched viewing experience.
- Clearly outstanding: Watch your graphics come to life on a vast 24" (61cm) LED-backlit screen featuring a crystal-clear 1920x1200 resolution on a 16:10 widescreen aspect ratio so you can’t lose screen area just because your customized applications support a different resolution.
- Contrasting view: Get ready for blur-free viewing with 2 million:1 (typical) high dynamic contrast ratio and 8ms with overdrive gray-to-gray (typical) response time that helps ensure crisp, sharp and ghost-free images.
- Colorful character: Enjoy an amazing range of rich, dramatic and accurate colors, thanks to IPS technology designed to give you color consistency across a broad viewing angle and a wide color gamut at 82% (typical).
- Premium Panel Guarantee: 100% replacement of Dell UltraSharp series monitors sold if any bright pixel is found, valid within the warranty1 period.
Specification:-
- 24" (60.96 cm) viewable area
- Widescreen (16:10)
- Panel Type, Surface: IPS (In-Plane Switching), anti glare with hard coat 3H
- 1920 x 1200 at 60 Hz
- 1000 : 1 (typical)
- 2,000,000:1 (dynamic)
- 300 cd/m2 (typical)
- 8ms (gray to gray) Typical
- 178º / 178º
- 16.7 million colors
- Color Gamut: 82% (CIE 1976)
- 0.27 mm
- 1x Digital Visual Interface connectors (DVI-D) with HDCP
- 1x DisplayPort(DP)
- 1x Video Graphics Array (VGA)
- 1x USB 2.0 upstream port
- 4x USB 2.0 downstream ports
- DC power connector for Dell Soundbar
- Height-adjustable stand, tilt , swivel , pivot and built in cable-management
- Flat Panel Mount Interface
- VESA Mount
Only £299.99 inc VAT.
ORDER NOW
Dell Professional P2411H 24" Widescreen LED Monitor - Midnight Grey @ £209.99 inc VAT
Fulfilling your demands for high productivity, great user comfort, and minimized environmental impact with EPEAT Gold rating, the Dell™ Professional P2411H 24”(61cm)W Monitor with LED is the ideal display for the professional office space.
- Environmentally sensitive: Use of recycled materials and halogen-free laminates in its circuit boards; arsenic-free glass and energy-efficient, mercury-free LCD panel to help reduce environmental impact.
- Puts you in the comfort zone: Raise, lower, tilt, pivot or swivel the P2411H monitor to fit your working style and enhance your viewing comfort.
- Excellent screen performance: The 24"(61cm) high-definition LED-backlit display performs brilliantly for complex tasks as well as everyday applications.
The Dell Professional P2411H monitor combines excellent connectivity and outstanding comfort with a superb front-of-screen performance for all your office productivity needs.
- Tilt, swivel and adjust the height of the P2411H to match your working style and enhance viewing comfort
- Use the pivot function to alternate between landscape and portrait views for excellent productivity
- Get convenient access to preset modes, brightness, contrast, menu, exit power button via the on-screen display control
- Secure the P2411H via slots for a security cable lock and stand lock (locks not included)
- Use the two USB 2.0 ports to connect peripherals such as keyboards, mice and thumb drives.
- Connect via the DVI-D(HDCP) port to enable high image quality
- Rely on the VGA port for everyday analog connectivity needs
- Enjoy a brilliant view with the high-definition LCD panel (active-matrix TFT) with LED backlight
- Experience vivid, lifelike details via the 2,000,000:1 dynamic contrast ratio (1,000:1 typical)
- Easily share the P2411H for group viewing, thanks to the 160º/170º wide viewing angle with 16:9 aspect ratio
- 5 ms response time (typical, black to white) designed to reduce ghosting and deliver razor-sharp images
Specification:-
- 24" (24" wide viewable image size)
- TN- Twisted Nematic, active matrix - TFT LCD
- 1920 X 1080
- 1000 : 1 (typical), 2 million:1 (dynamic)
- LED
- 250 cd/m2
- 5 ms panel (Black to White)
- 160°(vertical) / 170°( horizontal)
- Color Gamut (typical): 81% (CIE 1976)1
- Color Depth: 16.7 million colors
- Pixel Pitch: 0.277 mm
- Widescreen (16:9)
- 1x VGA
- 1x DVI-D with HDCP
- Height adjustable stand, tilt, pivot and swivel.
- Built in USB 2.0 High Speed Hub
Only £209.99 inc VAT.
ORDER NOW
Specification:-
- 178º / 178º
- 0.27 mm
- VESA Mount
ORDER NOW
Specification:-
- 1920 X 1080
- LED
- 250 cd/m2
- Widescreen (16:9)
- 1x VGA
ORDER NOW
